Running Spyro Using Command Line (A DOS box or a Macro)
Hi all
I would like to run multiple cases on SPYRO. The best way that I figured is to run it via macro or DOS which requires some sort of programming via a batch (.bat) file. The idea is to have SPYRO running in the background while an interface sets the multiple cases that needs to be ran.
Does anyone has experience on how to execute a case run in Spyro using command line. Currently I have been able to launch SPYRO by setting the directory and file name in a .bat file but it does not trigger the run automatically.
Any experience you could share or creating a batch file to execute a certain simulation programme is appreciated!
Best regards
Kelvin
Best regards
Kelvin
