How do I get back an erased datum or make a datum show up on drawing?
While making a drawing, I accidentally erased a datum plane. I want it back and it's not showing up, no matter what.
I Googled for the problem and it's solution, found tips on locating the feature on Drawing Tree and Unerase.
The problem is, The Datum is not shown in the drawing tree, but it is shown in Model tree. When I hover mouse (cursor) over features either from the Drawing Tree or Model Tree, It is highlighted in Green in the drawing, Except the datum plane which I want. (this datum plane, as previously said, exists in Model tree, but is not shown in Drawing Tree)
Can anybody please suggest a solution, workaround and/or any tip?
(I am using Creo 2.0)
Regards.
Regards.
RE: How do I get back an erased datum or make a datum show up on drawing?
Umm.. I tried that, Creo shows only X and Z datum plane but not the Y! (Which is what I want)
If you don't see it in your model tree, then you most likely permanently deleted it.
