Creo-Sub Assembly BOM
I have a drawing of an assembly, which contains a sub assembly, but I would like the BOM for the whole assembly to include the components of the sub assembly. I haven't been able to find a way to do this yet. I have the BOM started for the parts that are not n the sub assembly but can't figure out how to add those last couple parts.
Hopefully there's an easy way to do this without rebuild the whole assembly.
Thanks!
Thanks!
RE: Creo-Sub Assembly BOM
You haven't said which version of Pro/E you are using, but if you search the help files for repeat region, you can get how to access the menu options - one is for Flat/Recursive/Recursive no repeats.
