MEASURE OF THE : ROOT OPENING AND THE ROOT FACE THICKNESS
Good day:
I want to know how dimention the root opening and face thichness in a weld , i guess that it is function of : process, material, amperage etc, are recommended values?
Than you
JATE
Than you
JATE
RE: MEASURE OF THE : ROOT OPENING AND THE ROOT FACE THICKNESS
JATE, take a look to Figs. 3.3, 3.4 and 5.3 of the Structural Welding Code - Steel AWS D1.1 - 2010. As a complement, go to this link http://www.jflf.org/pdfs/papers/fabguide.pdf (page 23).
El que no puede andar, se sienta.
