NX 7.5 Advanced Simulation Solver error (No Parrallel Process)
I have a fairly simple geomtry set up with straight forward criteria. The check commands relay the meshing is without error and the loads/constraints are all stable but when I hit solve the following error comes up:
RE: NX 7.5 Advanced Simulation Solver error (No Parrallel Process)
Forget the parallel eror, take a look to the *.F06 file and look for the word FATAL, there you will see the reason of the error.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
Thanks for responding. The issue is actually a licenseing issue. I just learned how to fix it a few hours ago.
