Vacuum Calculation
Vacuum Calculation
I have attached a snap of the Vacuum system. can anyone please help me to find the Vacuum need to create in the chamber so that fluid from the reservoir suck into the Chamber?
Bambila
Bambila
Bambila
Mechanical Engineer
RE: Vacuum Calculation
You will have to convert to your units.
The liquid needs to rise 0.55m assuming your reservoir level doesn't change. Therefore the pressure in bar required to lift this is m x sg /g. As this is negative from atmospheric the pressure in the chamber needs to be 1 barg- (0.55 x SG /9.81).
Still looks like homework though....
Can you please explain how this equations are derived or provide me any reference material?
Bambila
Mechanical Engineer
Isaac Newton came up with the basic equations....
I got this out of Cameron Hydraulic Data, but any reference on basic fluid flow should have it.
