Rotate geometry in sketch mode using reference line
In Autocad there is a command to rotate a geometry in sketch mode using a reference line instead of an angle. I can't seem to find this command in Inventor 2013. Does somebody know where to find it or have another simple way of doing it?
RE: Rotate geometry in sketch mode using reference line
What about a parallel or maybe collinear constraint?
This requires that all the lines dimensions/constraints is specified, if you don't want to mess up the geometry.
But there isn't any way of rotating it without having to specify the dimensions first?
(Let's say in a case when I really want to dimension the geometry afterwards)
Thanks!
Attach your *.ipt file here.
Thanks a lot!
