Linux Licenses
Linux Licenses
Linux Licenses
Does any one know how to make a Linux install read a Mach Bundle? I switch to mach bundles from A la carte I am having trouble getting my grip_batches to run its acting like there is no licenses
Ryan Lee
Mechanical Project Engineer
NX 6.0.5.3
NX 9.0.1.3(Testing)
If you can think it it can be modeled
RE: Linux Licenses
Should be no difference from a Unix or Windows install.
Does the Linux license have the Mach Bundle in it?
Can you ping the Linux license server from your workstation?
Does the Mach bundle include a line for GRIP Execute?
Ben Loosli
RE: Linux Licenses
I can ping the license server just fine. My linux box uses the same licenses server that my windows stations do. Its in on a windows machine running flex lm and has been for about 15 years. This worked up until last week when Siemens cleaned up all the a la carte out of my licenses file and now it just has the Mach bundles grip author 2 extra gateways. The mach bundles have grip execute in them. I just figured i had to select the bundle like you do in windows.
I used to have stand alone license of grip run-time but i thought mach bundles replaced the need for it
Ryan Lee
NX 6.0.5.3
NX 9.0.1.3(Testing)
RE: Linux Licenses
Sounds like something that GTAC should be able to help you with.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: Linux Licenses
Just a follow up you have to set your env var for mach bundles when using them in Linux UGS_LICENSE_BUNDLE=NX..... works fine
Ryan Lee
NX 6.0.5.3
NX 9.0.1.3(Testing)
