Where is "Delay View Update" in NX9 Preference Drafting
Where is "Delay View Update" in NX9 Preference Drafting ?
I was able to set in the Customer default but it doesn't work
Thanks in advance
Thanks in advance
Didier Psaltopoulos
http://www.psi-cad.com
RE: Where is "Delay View Update" in NX9 Preference Drafting
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I think the issue is that the template part is overruling the customer defaault.
Thanks for this information, but have a look at the video ? It doesn't work
Hi Joe,
I don't agree with you
Thanks in advance
Didier Psaltopoulos
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
What we did in NX 9.0 was move the 'Delay View Update' to a more 'logical' location since it's really a global setting. You can now find the toggle at...
Menu -> Tools -> Update -> Delay View Update
While I don't know this for sure, I suspect that eventually these 'Update' options will move to some more easily discovered place on one or more Ribbon Tabs.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks John
It works like NX8.5 when doing some modifications in modeling
But I found a limitation that maybe exist also in NX8.5 when doing some modifications in drafting (with PMI bidirectionnal):
If we edit a PMI dimension in the main drafting view, this view update only. The sheet remain "Out Of Date"
If we edit a PMI dimension in another view this view doesn't update
Have a look at the video
Didier Psaltopoulos
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
three location for the update view setting ?
Are too much..users are disoriented.
Thank you...
Using NX 8 and TC9.1
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
1) Customer default
2) Drafting preferences
3) Menu -> Tools -> Update -> Delay View Update
Where the last can override the second.
This is new in NX9.
If I remember, you didn't know the existence of the last setting, you had investigate.
If a person like you don't know this new situation,I can't imagine an user that has problems like Didier resolve this problem.
Make CAD simple and converge setting in one place.
Thank you...
There is no more setting in Drafting Préférences and it's normal that "Menu -> Tools -> Update -> Delay View Update" override the Customer default
I could find by myself the new place of the setting with "command finder" but I had forgotten it
Didier Psaltopoulos
First off, the Customer Default presets the 'Delay' option ONLY for new Drawings being created from scratch. Changing this setting will have NO effect whatsoever on any existing Drawing files.
As for the second place, Drafting Preferences, as Didier has already pointed out, the 'Delay' setting is NO longer there. What is there, and which always has been there, is the option of toggle ON whether NEW views being created will 'Automatically Update' or not. The status of this setting is inherited by each NEW Drawing view as they are created. And once created, this setting can be changed, by using the new 'View Settings' function on a view-by-view basis. Again, this is NOT new.
And for the third location, at Tools -> Update, yes this is a NEW LOCATION, but the behavior has NOT changed one bit. This setting is on a per Drawing basis and at the time the Drawing was created (OR when the Drawing template was originally created) the Part file inherited the status of the 'Delay' setting from Customer Defaults. But once a Drawing exists, you can override the Customer Default setting by now going to Tools -> Update (prior to NX 9.0 you did this in Preferences -> Drafting). The purpose of this option was to disable, when toggled ON, any of the 'Automatic' settings on the Drawing views themeseleves. Toggling this option ON provided a way that when a Drawing was opened, that it would come-up as fast as possible since Drawing views would NOT be forced to update even if the changes made to the model(s) were minor. It left the control of this update in hands of the user who could so snytime he wished using the 'View Update' function found on the Drafting interface. This can be very important in the case of Drawings of large Assemblies where out of hundreds of Components maybe only one simple part has changed yet this change, if the 'Delay' setting was NOT toggled ON would force the entire Drawing to update, which could take a long time. That is why, out-of-the-box, this Customer Default is toggled ON by default.
So the bottom line is that as far as behavior is concerned, NOTHING HAS CHANGED! The only thing that has really changed is that in the restructuring and reformatting of the Preferences/Settings dialogs it was decided to move 'Delay View Update' to where the rest of the 'Update' options were located.
As for why I missed this myself, I was going by the What's New Guide as well as the functional specs for the various project that I was part of the review process during development (and for the record, I don't review EVERY single project for each release of NX, as there are hundreds, many in areas where I can add little if any value). Note that I have been in contact with the people responsible for moving this setting and have recommended that even in the case of something as minor as this, that it would have been good if this had been noted in the 'What's New Guide' since many people, myself included, uses this document as our first source when looking for what has changed and WHY.
Anyway, I hope this clears-uo any confusion that this might have caused.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Very good
Didier Psaltopoulos
Then, there are three setting for the automatic update view.
Thank you...
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
