Digital potentiometer
  Is it possible that a digital potentiometer can serve as a feed back element in a frequency to voltage converter loop. I do convert the Analog signal(5v) from the F/V in to a digital one through a comparator (the other input is from a high precision voltage reference of 5v). Can u make a suggestion about this.
Thanks in advance for your inspiring replies,
Senthil
RE: Digital potentiometer
Your problem isn't very clear.  What do you wish to do with the digital pot?  Use it as a divider, or part of a divider to feed a signal back to your comparator?
yea it is a divider the adjust the frequency, but the feed back is not the comparator instead to the F/V converter.
Senthil
Hi Senthil,
  I can't say I understand quite hoe you propose to use the device, but you can certainly use a digital pot as a voltage divider as long as you stay within the voltage and current restrictions of the device.
Good luck,
Bruce
Do note that if your application involves high frequency or other reactive circuitry, the digital potentiometer is not strictly a variable resistor and can produce odd effects.
TTFN
The dig.pot is just a D/A converter -- so it can be used in feedback. It may have memory or counter -- which may
emulate an integrator.
<nbucska@pcperipherals.com>
