Break links between Assemblies
Hi All,
I have a question. When i use send to directory for a product file i get many links which are not relevant to the current window. How do i break these links? I have tried Edit...links...but the "isolate" is not highlighted.
To explain you clearly in my send to directory dialog box i get many files and links which point to documents which are not relevant to the current product?
Any helps ? Thanks in Advance.
RE: Break links between Assemblies
I have this same problem. You need to determine what files have links to other documents which are not part of the current project and remove those links. A CATDUA process may be necessary as well to remove all links
Thank you so much jopal for your reply. Will try that and get bk to you.
