Pressure loss in a circle shaped pipe
can any one help me?
I have a circle shaped pipe ( originally a spiral), and wanna calculate the pressure loss of this pipe, any idea?
Thanks a lot
Thanks a lot
RE: Pressure loss in a circle shaped pipe
Assuming you figure that out, I would go for an equivalent length principle based on the radius of your circle looking at the many equivalent length formula out there.
Good luck,
Latexman
Technically, the glass is always full - 1/2 air and 1/2 water.
http://nvlpubs.nist.gov/nistpubs/jres/18/jresv18n1...
http://neutrium.net/fluid_flow/friction-factor-for...
Are you talking about a "Ring Header" (one complete circle) such as would be used for fuel gas to the burners of a Petro-Chem heater?
The goal here is not to have pressure drop bot equal pressure at all burner laterals.
prognosis: Lead or Lag
