FRP Pipe Installation Cost
I need to install in a chemical plant a whole network of vent lines coming from the reactors and going to scrubbers and oxydizer.
Client requested to have these lines in FRP (Fiberglass).
Can someone tell me what is the installation cost of this kind of pipe.
I'm looking for an easy way to estimate the cost, preferably in $/inch.
Or has anyone a ratio to compare it to stainless steel for example?
Thx
Mathieu
Thx
Mathieu
RE: FRP Pipe Installation Cost
Installation costs are quite high and actually based more on cost/time per joint not really dependent on size. If you get more than two or three joints a day you're doing well, on the basis that they are glued.
The decision to use GRE is often based on long term lack of maintenance/ no corrosion, not material and installation costs.
I would guess it's two to three times stainless installation costs if you're using glued joints. Maybe less if you're using only screed or o ring type connectors. You need to be slow and careful with this type of pipe otherwise you'll run into lots of problems.
It seems that below a certain diameter (around 6 or 8'') it is cheaper than stainless steel, but it becomes way more expensive above that.
"If you get more than two or three joints a day you're doing well. . "
and do not forget to add in the cost for the curing 'heater blankets'. Most FRP/GRE epoxy wants to cure at 80°F / 27°C. And the epoxy kits have to be kept at that temperature until time to mix it up. Usually means a pickup truck idling with the heat on.
