advantage of metal spraying over weld overlay
Dear all,
what is the advantage of using metal spraying process w.r.t weld overlay.
regards,
RE: advantage of metal spraying over weld overlay
Productivity, avoidance of PWHT and minimisation of metallurgical interaction imperfections. Corrosion performance might not be comparable though.
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
Little to no distortion of the component.
If it a low temp application and you can use a sealer then the corrosion performance of metal spray is pretty good.
There are numerous metallization processes, they cover a wide range of materials and performance.
Be careful about lumping them together.
Under very high loads or impacts weld overlay would be preferred.
Plymouth Tube
