turning radius
turning radius
I am a stuctural guy trying to help someone with some drafting standards. I have been tasked with finding the turning radius of a HS-20 truck. I can't find this information anywhere, but I have found the turning radius of several vehicles. All I can find about HS-20 trucks is the load pattern. My question is this, is a HS-20 the name of the load pattern that develops from a truck, not the actual name of the truck?
RE: turning radius
http://www.enggpedia.com/civil-engineering-encyclo...
http://www.codepublishing.com/wa/ClarkCounty/clark...
TTFN
RE: turning radius
RE: turning radius
State of California Highway Design Manuals:
http://www.dot.ca.gov/hq/oppd/hdm/pdf/english/HDM_...
Topic 404 – 3
For Federal Standards please refer to the following reference:
https://bookstore.transportation.org/collection_de...
A Policy on Geometric Design of Highways and Streets, 6th Edition
As you will note by reviewing the foregoing references the HS – 20 designation is no longer used.Please refer to your state standards for the proper template to use.
Editorial:
H= Highway
S= Semi Trailer
20= Twenty Tons(total weight of tractor and trailer) If you are interested in load distribution and patterns refer to AASHTO bridge design
RE: turning radius
Dik
