control a value defined by a range in PartFamily
hi -
does someone here here know ,if it will be possible to define a cell in a spreadsheet,
so the values are in a range eks. -90 tp 90 deg ,5 deg step.
I will use at , in this case when I want to control an angle of a schackle, when I add the partfamily. In this case I only need one size (one variant),
but I it will be possible to could control the angle.
I try to avoid to create a partfamily for each angle ,while it is the same variant .
lklo
