Choppy rotation point pan rotate 8.0 was fine 8.5 not
I have a larger model on screen fit to viewing area. I want to zoom in and rotate/pan around a certain area. I hold in mb2 to lock in the rotate point, while holding in mb2 I zoom in,pan,rotate with space ball, release space still holding mb2, click mb3 while still holding mb2 to pan and the model abruptly jumps way off sometimes off screen. This never happened prior to 8.5. Is there a setting I can toggle for this not to happen?
RE: Choppy rotation point pan rotate 8.0 was fine 8.5 not
I could not replicate the same behavior at my end (may be i am missing your point).
But yes some significant enhancements were made for Rotation in NX8.5 ( like an arbitrary center of rotation located in the center of the visible geometry). There are some more and if i am not wrong then these are discussed in quite a detail way in older posts.
Thanks and Best Regards
Kapil
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Khimani Mohiki
Design Engineer - Aston Martin
NX8.5
Another thing with mb2 hold for rotate point is that after you hold and set point and zoom, if your in an operator, when you let go of mb2 it goes to the next input like you mb2 to select next input
Another thing with mb2 hold for rotate point 8.5 is that after you hold mb2 set point and zoom, if your in an operator, when you let go of mb2 it goes to the next input like you mb2 to select next input. This was not the behavior on 7.5
