how to perform energy balance across centrifugal compessor
hello,
this my first participation in this helpful forum, so I need some one to help me performing energy balance across centrifugal compressor working on natural gas by answering following questions :
1- what is exactly rated power of compressor driver ( for example gas turbine) is that the net power ready to be received by compressor shaft or it is the gross power produced by driver before any efficiency values applied ?? for example if I say that rated power of driver (gas turbine) is 27 mw is that mean compressor can take all this value ( when needed) or the actual quantity of power compressor can take is (27 * efficiency )
2 - how I can calculate energy added to gas inside compressor (by speed of rotation) and energy lossed by recycling the flow from discharge to suction (when opnening surgeline) and also how to convert between pressure and energy
thank you in advance for any help
ahmed bahgat
ahmed bahgat
RE: how to perform energy balance across centrifugal compessor
2. The easiest way is to take your compressor map and to see at current speed, pressure ratio and flow how much is power consumed. If you don't have it (wich would be strange) you should calculate it as isentropic power.
About the power losses through recycle line: discover the flow, you know inlet and outlet pressure and temperature of the line, you should know the molecular weigth of the gas - no problem to calculate the power losses.
You can not convert pressure to energy becаuse the pressure is force to area but energy is power for time.
thank you again
