Bearing design
Bearing design
I have an overhung fan mounted from two pillow block bearings. I’m trying to work out the bearing loadings, but so far I can only find calculations which look for kN loads, whereas I’m looking at a moment load-if the fan is mounted at a greater distance, the moment load on the bearings has to increase (while the mass stays the same) and vice-versa. Any ideas on how I can resolve my moment loads into forces?
RE: Bearing design
RE: Bearing design
Sum of the moments at any point.
page A-23 here -
http://www.ntn.co.jp/english/products/pdf/ball/pdf...
RE: Bearing design
