NX 9.0.1.3 Strange Behavior for Measuring Distances and Diameters
I have noticed strange behavior when measuring distances and diameters in NX 9.0.1.3, in the modeling module. To replicate problem:
1. In the ribbon, click “measure distance.”
2. Select type “distance,” measure something, and press “ok”.
3. In the ribbon, click “more->simple diameter.”
4. A dialog box comes up which says “measure diameter” on the top but which has a type of “distance,” which does not actually make sense for a diameter measurement. (see screenshot)
5. If in the diameter dialog, you select and measure a diameter, then when “measure distance” is clicked in the ribbon, the box pops up with a type of “diameter,” the same problem in reverse.
I think many of the items in the measure portion of the analysis ribbon are linked similarly, such that clicking the desired option in the ribbon does not result in the expected measurement type in the dialog box.
Ryan Lee
Mechanical Project Engineer
NX 6.0.5.3
NX 9.0.1.3(Testing)
If you can think it it can be modeled
RE: NX 9.0.1.3 Strange Behavior for Measuring Distances and Diameters
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I made a movie to show the behavior. Any ideas when MR2 going to be released
Ryan Lee
NX 6.0.5.3
NX 9.0.1.3(Testing)
Ryan Lee
NX 6.0.5.3
NX 9.0.1.3(Testing)
As for the release schedule of NX 9.0.2.x, if all goes well, you should see something a week or two before the Siemens PLM Connections event in Orlando.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Ryan Lee
NX 6.0.5.3
NX 9.0.1.3(Testing)
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Ryan Lee
NX 6.0.5.3
NX 9.0.1.3(Testing)
I'm thinking it's to do with the role you're using or a dialog memory problem.
I looked at your video and below is an image showing your video and NX9.0.0 and NX9.0.1 on top.
The dialog you have is called Measure Distance, whereas on both of mine it's called Simple Diameter.
Subtle, but it tells me that the dialog you are using must be different, even though you're clicking on Simple Diameter.
FYI, I only just installed NX9 yesterday after a rebuild of my computer and the role being used is NX9 Advanced.
Anthony Galante
Senior Support Engineer
NX5.0.6, NX6.0.5, NX7.5.5, NX8.0.0 -> NX8.0.3.4
NX8.5.0.23 -> NX8.5.2.3 & NX9.0.0.19
Ryan Lee
NX 6.0.5.3
NX 9.0.1.3(Testing)
