ANSI Y14.5 2.5 SINGLE LIMITS ?
Dimensioning a forging with a size dimension ie: "6.0 MIN".
Per 2.5 I interpret the size limit to be 6.0 to infinity.
There are others that say the drawing tolerance block dictates the maximum size tolerance with the dimension decimal places.
RE: ANSI Y14.5 2.5 SINGLE LIMITS ?
John-Paul Belanger
Geometric Learning Systems
You are correct, your colleagues are at best ignorant.
ASME Y14.5M-1994 section 2.5 Single Limits
...Single limits are used where the intent will be clear, and the unspecified limit can be zero or approach infinity and will not result in a condition detrimental to the design.
(Sorry, I'm in a bit of a bad mood today and my gladly suffering fools threshold is a little low.)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
In this case the intent is clear, but either zero or infinity are not acceptable
