NX85 - Add Component is by default Non-Geometric ?
Just started with NX85.
While adding a component to an assembly it appears by default to be in a Non-Geometric state...
Is there somewhere a setting to change that behavior ?
RE: NX85 - Add Component is by default Non-Geometric ?
So the bottom line is, I have NO idea how you could possibly be seeing this behavior, unless the components are being placed using some sort of journal or NX Open application where someone has modified this behavior on the fly.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
After a little investigation it appears that some of the components that have a "DB_UNITS" attribute with a set value follow that behavior of being added as "Non Geometric". GTAC explains that also as a "by design" intent on that NX version...
Since I am just testing some of our .NET programs in Native mode and that attribute is set blank in our Teamcenter production mode the plroblem is solved!
Thank you.
D.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
