Aluminium 1050 and offshore usage
We use aluminium with a low amount of alloy (1050 or 1060) for finning of tubes for air cooled coolers. Often these coolers are used offshore and then the clients are asking for 'marine grade aluminium'.
Now the question is: how can I prove that the used aluminium grade is suitable for a marine environment, is there a standard (ASTM/ISO/EN) which I can use?
RE: Aluminium 1050 and offshore usage
Boatbuilding with aluminium, Stephen F. Pollard, 1993, International Marine, ISBN 0-07-050426-1
http://www.alcoa.com/mill_products/europe/en/pdf/N...
ASTM B928 / B928M - 09, Standard Specification for High Magnesium Aluminum-Alloy Sheet and Plate for Marine Service and Similar Environments
Consider offer a protective coating like: Electrofin. We add it to all our marine heat exchangers (copper and AL fins.
http://www.titan-air.com/toolsresources/Technical%...
This extended our marine coils from 3 years to 10+.
