View from 3D Rotate
View from 3D Rotate
View from 3D Rotate
I am cutting the 3D view section in 3D Modelling.(Annotations-Views/annotation Planes-- Section Cut/Annotation Plane). Then i am placing this cut section views in drawing.(View from 3D).
But i will get the section view rotated not like what i desire..then i will rotate the view by changing the properties of the view angle. Can any know please is there any way i can directly place the view in drawing as in desire rotation.
I am using Catia V5,19
Thx
BGD
RE: View from 3D Rotate
Create the View directly in the drawing using the Offset Section View command with the parent view active. This will align the section view with the parent view. Instead of defining the cutting plane line, select the Plane used to define the FTA Annotation View.
