SWX 2014 SP2.0 Downloading Problems
Are any of you having problems downloading SP2.0? I had the same problem at home last night and at work today: "The downloader could not be started due to an internal error. Try downloading manually." And then: "Download Error
Installation files could not be downloaded because: Internal Error: CoCreateInstance({652E77B7-69AA-491B-8C64-25B79239863F}) FAILED. If the problem persists, a proxy server might be preventing automatic downloads. Choose the option to download files manually instead.
For more information on download errors, visit the Customer Portal."
Yes, I can download manually. I did that for my home installation, but I want to know if others are seeing something similar. We have several installations at work plus everyone's home installation. I would like to know if all of them will have to be done manually.
- - -Updraft
- - -Updraft
RE: SWX 2014 SP2.0 Downloading Problems
Chris, CSWA
SolidWorks 13
ctopher's home
SolidWorks Legion
SW Professional 2014
SW Electrical 2D/3D
64 bit SP1.0
Intel Xeon X(R) CPU 1603 0 @ 2.80 GHz
8.0 GB of RAM
NVIDIA Quadro 2000
Scott Baugh, CSWP
FAQ731-376: Eng-Tips.com Forum PoliciesBerry Plastics
Cad Admin\Design Engineer
GEASWUG Greater Evansville Area SWUG Leader
www.scottjbaugh.com
I was just asking if anyone else was seeing the same problem I was. I thought it strange that it appeared identically on my home machine as well as at work just 12 hours apart. Chris, At home it is installed directly on my 64-bit Windows 7, so there is no issue with Win 2003 Server.
I suspect there might have been a server or traffic problem at SWX at the time. I have since been able to download at both locations without these errors so all is good.
Thanks for the replies and ideas.
- - -Updraft
Chris, CSWA
SolidWorks 13
ctopher's home
SolidWorks Legion
