construction inspection
Hi guys,
I’m new to U.S. construction flied, and next week they ask me to go out for RC checking. What is the term they use to check the steel bar pattern etc in the construction field? do they also submit steel bar manufacturer's certificates ? If so do they call differently?
Thank you
tsli
Thank you
tsli
RE: construction inspection
Brush up on your english or spanish cursing and you'll do fine.
- Inspection (you've checked and YOU certify that it is perfect)
- Review (you've checked a substantial sample of your choosing and can say that the method of work meets with all requirements of the construction documents)
- Cursory visual review
In all cases record where you went, what you did and did not see, and make sure you make only specific statements.
You can use the mill markings and deformation/rib pattern to identify the mill which produced the bar, the strength grade, the associated ASTM specification, and bar size. You can download a digital copy of our Ready Reference Guide from crsi.org, by clicking on the webstore link.
Dik
