The new option "Alternate Dimension Endpoints" is always grayed out in Drafting Linear Dim
The new option "Alternate Dimension Endpoints" is always grayed out in Drafting Linear Dimension NX9
Does anybody could confirm or maybe I am wrong ?
Didier Psaltopoulos
http://www.psi-cad.com
RE: The new option "Alternate Dimension Endpoints" is always grayed out in Drafting Linear Dim
Home -> What's new in NX9 -> CAD -> Drafting -> Alternate Dimension Endpoints
www.nxjournaling.com
I confirm that I am using exactly the information in "Home -> What's new in NX9 -> CAD -> Drafting -> Alternate Dimension Endpoints"
Have a look at the screenshot
Did you try it ?
Didier Psaltopoulos
Are you sure you are dealing with arcs and not intersection curves or splines?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
OK, I was trying using it when placing dimension on solid not on sketch !!!
Is there a limitation or am I wrong ?
One question: Cowski, How did you put image on your post ?
Didier Psaltopoulos
I uploaded it to engineering.com, when you press OK a dialog comes up giving you the file location, something like www.engineering.com/getfile.aspx.bigjumbleofletters-filename. Copy the address, use eng-tips' picture tag and paste the address in it, but make sure to change the getfile to download. Use the preview function to make sure it is going to work, tweak as necessary.
Have a look at the video. I am selecting edges type arc !!!
Didier Psaltopoulos
Thanks a lot for the tips
Didier Psaltopoulos
