Reason of error
Reason of error
I'm not looking for a solution, but only understand the reason of this error.
As you can see, the Extrude(6) fail.
Why the 'until next' is not aceptated by NX, in this case ?
How NX ratiocinates with this option enabled ?
Thank you...
Using NX 8 and TC9.1
RE: Reason of error
The issue is: no new material is added to the solid in this case.
The defining curves are coplanar with the top surface and the "until next" option uses the side and bottom faces to trim your new extrude. "Until next" looks at all the faces your new extrude interacts with, not just the bottom cap face.
www.nxjournaling.com
RE: Reason of error
Sorry but SolidWorks and Solid Edge in this case add material and Parasolid is the same engine.
Thank you...
RE: Reason of error
If you change the boolean option to "none" you will see what the extrude command has created.
I was answering in context of how NX works, which I thought was what the original question was asking. Personally, I don't often use the "until..." options as they are prone to update errors. I think they can be improved upon and possibly combined. If you'd like to see a change/improvement, your best option is to contact GTAC with an IR/ER.
RE: Reason of error
In NX the option "Until Next", the "target face" for the extrusion must be large enough to cover the Full area of the extrusion. If not one must use the "Until extended" which will extend the target face. Probably this is implemented differently in SE and SW.
Tomas
