Extract coords from point set in NX and write to text/Excel
Hey guys,
I have a pre-defined point set in my NX part file that contains 16 points and I have it titled as "pointset1" within my part file. I am attempting to write/execute a VB code that will extract the global coordinates from those 16 points and write them to a text file for convenient output to Excel. I guess the smart thing to do would be to write them directly to an Excel spreadsheet but I am (completely) new to VB and I'm not sure if that is possible and I wouldn't know where to begin! For the time being, writing to a text file seems fine. Anyway, I've taken a crack at it and pasted my VB code below. When I try to run it from the Journal editor I get the following error message: Object reference not set to an instance of an object. at NXJournal.Main() in C:\Users\tlemonds\AppData\Tempe\NXJournals8036\journal.vb:line21. This is my first attempt at writing some VB code so I wouldn't be surprised if I'm doing something very "obviously" wrong. I do suspect that I am not defining "pointset1" correctly and I'm honestly not sure if it matters that I am executing this in Journal editor or if I need to execute it via some other platform. Any guidance provided would be much appreciated!
' NX 8.5.0.23
' Journal created by tlemonds on Sat Feb 15 14:11:58 2014 US Mountain Standard Time
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.Utilities
Imports NXOpen.Features
Imports NXOpenUI
Imports NXOpen.UF
Module NXJournal
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Sub Main ()
Dim obj1() As NXObject
Dim pointset1 As PointSet = pointset1
obj1 = pointset1.GetEntities()
End Sub
Public Sub WriteCoords(ByVal obj1() As NXObject, ByVal pointset1 As PointSet)
FileOpen(1, "coords1.txt", OpenMode.Output)
Dim header1 As String = "Control Point Coordinates (inches)"
Write(header1)
Dim xstr As String = Nothing
Dim ystr As String = Nothing
Dim zstr As String = Nothing
Dim feat1 As Feature = DirectCast(pointset1, Feature)
Dim name1 As String = feat1.GetFeatureName
WriteLine(name1 & "X Y Z")
For i As Integer = 0 To 16
Dim pt As Point = DirectCast(obj1(i), Point)
xstr = FormatNumber(pt.Coordinates.X, 3, , , TriState.True).PadLeft(20)
ystr = FormatNumber(pt.Coordinates.Y, 3, , , TriState.True).PadLeft(15)
zstr = FormatNumber(pt.Coordinates.Z, 3, , , TriState.True).PadLeft(15)
WriteLine("Point " & (i+1).ToString & xstr & ystr & zstr)
Next
End Sub
End Module
' NX 8.5.0.23
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpenUI
Imports NXOpen.UF
Module NXJournal
Sub Main ()
End Sub
Write(header1)
Next
End Sub
End Module
RE: Extract coords from point set in NX and write to text/Excel
www.nxjournaling.com
thread561-358929: Which should I use - NX Open GRIP, Python, VB, etc.... ?
