lightweight dynamic cone penetrometer(DIN 4094)
I want to use a German type lightweight dynamic cone penetrometer(DIN 4094)to determine the allowable bearing capacity as part of a ground investigation. I remember sometime ago I read that ten times the N10 value gives the allowable bearing capacity in kPa.Can somebody confirm this or give me the correct relationship between the two parameters?
RE: lightweight dynamic cone penetrometer(DIN 4094)
BigH, the european lightweight (DPL) is similar in concept to the Macintosh probe although a little different, a heavier weight is used and blowcount is every 10 cm. Many professionals regard it as a toy, not fit to yield quantitative values of geotechnical parameters, good for shallow layers thickness though, if soft.
I personally like the Canadian pentest - 60deg cone driven with SPT hammer and drop. This is not a toy! Always found it very useful.
BigH, the pentest is probably similar to the super heavy dynamic probe, which has an impact energy similar ot larger than the SPT.
I concur it's very useful, unless the soil is cohesive and the drillpipes start sticking to the borehole, creating fallaciously high blowcounts. Cohesive soils are the realm of the static penetrometer.
