bridge pier question
Hi guys:
I am need to doing construction business, not to mention structtural. I have just received a site photo. As shown on the attached photo in link below can anyone identify what is back object surrounded by the re-bar? in what construction stage they put up the object?
Tsli001
Tsli001
RE: bridge pier question
If this is for a bridge pier it looks to be part of a precast, segmental unit that will be combined with many ohters (post-tensioned together) to form a tall bridge pier. That said, I do not see any P/T ducts installed as of yet. It's not a cast-in-place form as there is no reinforcing steel extending out of the floor into the form.
As to what stage this is it appears to be early in process of precasting as only the inside form and some rebar is set. The spacers are also present ot make sure there is the correct clear cover on the inside and outside faces.
I hope this helps.
Qshake
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
