Steel Plate Walls
Steel Plate Walls
attached is an image of the section for steel panel/plate walls. They will be load bearing and at a 45 degree angle with a plate embedment to a concrete footing. Not a whole lot of load, just a typical 20 psf and self weight of purlins and beams (steel). I am considering getting Design Guide 20 for further help on these walls, does anyone know if that's a good guide for something like this? Is there anything else you would recommend as a design guide?
