Is there a standard that requires a parts list (or BOM) in a certain section/placemnt of the print?
Is there a standard that requires a parts list (or BOM) in a certain section/placement of the print?
RE: Is there a standard that requires a parts list (or BOM) in a certain section/placemnt of the print?
What I mean is does the parts list have to be on the bottom in the middle, left corner, right corner, upper corner, lower corner, etc? If there is such a standard, where would I find this?
Thank you!
Where they require it seems to take a ton of paper real estate.
Thanks!
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
