Show detail view as solid in drawing.
For regular views you can show them as solid by going to "properties->view->view generation mode" and choosing raster and picking shading under options.
I created a zoomed detail view. When I go to do the same steps, there are no options other than "exact view" under "view generation mode"...
RE: Show detail view as solid in drawing.
You cannot do it with the Detail view. You can do it only with the other views.
Lame...
Thanks for the reply though.
I Believe what Tarthrin wanted to know is if the part can be shown shaded in
2d like you can do in solidworks.
I do know how to show the part shaded. However, when you do a detailed (zoomed) subview there does not seem to be the same option.
may be you can use a quick detail view instead of Detail view ?
The Quick Detail View can be shaded.
Eric N.
