automatic paper size in drafting
I've made a model in NX 8.5 that I can adjust by parameters. I've placed some views in drafting mode on a A4 size paper. Now i'm wondering, is it possible that when I adjust the parameters and make my model bigger that the drafting takes a A3 size paper? Maybe it is possible to set a range so that when it is between ... and ... it is A4 and when it is greater than that it takes a A3.
Thanks in advance!
Tim
RE: automatic paper size in drafting
Do you have Teamcenter ?
I really can't think of a way to do what you want, but I came up with something else that may help out:
1) create the A4 drawing and add the views, dimeensions and notes to the drawing.
2) Create an A3 drawing on sheet 2, and copy the view to that sheet (the dimensions with come ewith the copied view), also copy the notes over
3) After you adjust your prarmeters look at both sheet 1 (the A4 size) and sheet 2 (the A3 size), then decide which is best for you and delete the one that you do not use.
One more tip:
Do you know that you can adjust the scale of the drawing view via an expression? so when the part grows you may want to make the view scale smaller.
Thanks for your answer! But I think it is not exactly what I want. I don't know about the scale of the drawing via expressions, can you explain me something about how to set these settings to let it work?
Thanks!
The last two weeks have been busy for me but
here is something to get you started . . .
The image shows the view syle menu and where the expressions button is
From there you probably want to create an if-then-else statement in the
expression that controls the view scale.
I will try to post an example in a few days.
If you create Drawing templates using the tools in NX, when they are applied to a model using the Master Model approach, they will automatically determine the proper Drawing scale to be applied to the views based on the size of the model. And before anyone asks the scales being used will comply with standard Drafting practices based on whether you're working in Metric or Imperial units, such as 10:1, 5:1, 2:1, 1:1, 1:2, 1:5, 1:10, etc for Metric and 8:1, 4:1, 2:1, 1:1, 1:2, 1:4, 1:8, etc for Imperial units.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
<sarcastic note on>
Who uses stanard view scales these days?
Engineers have the ability to make any scale they want. 51/300, 17/100, 3/10, etc.
<sarcastic note off>
I am glad at least Siemens is defining standard scales in their drawing templates. I get so tired of telling the designers I work with that those are standard scales for engineering drawings and should be used.
Ben Loosli
John,
I'm curious... does the software take into account the number of features to be dimensioned per view when determining view scale, or just the part envelope size? I can see how it would be great for simpler parts, but it seems questionable for more complex parts.
I'm all for standard scales, but it seems to be less of an issue if all of your prints are 11"x17". winky smile
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
It only looks at the bounding volume of the part file or Assembly.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
