Insulated Rails in Petroleum Dock Facilities
To prevent people fom falling of our docks, we installed metal rails at the edge of our docks. Thus we have metal rails between our pipe manifolds and loading/unloading ships or barges. To conform with regulations we install insulators at our manifolds. The problem that I have now is that we use rubber hoses with a spiral wound reinforced metal exterior. When a ship is loading/unloading the hoses touch the metal rails. Thus, the ship is no longer isolated from our docks. I wanted to know how other facilities deal with this problem.
RE: Insulated Rails in Petroleum Dock Facilities
th above offeers simplicity, low cost, electrical disontiinuity (can also band w/ fiberglass or HDPE strapping iis SS gives you electrical discontinuity angst. I expect the ss strapping to ned up well below th surface when cinched up, but try severaal strapping materials to find what works best.
good luck,
rex
