On catia v5, how do I draw a spring and represent 3d threading
I have to build a  spring prototype on a rapid prototyper and I try with no success to draw a spring on Catia V5, how do I do??
Also, I would like to represent 3d threading  and after build the part on a rapid prototyper. I use the treading fonction but I don't have the 3d representation, I think that this fonction is for drafting only.
thanks
Petecul
RE: On catia v5, how do I draw a spring and represent 3d threading
hi,
in order to draw a spring you gotta use helix function in GSD for exemple, and use the curve as a center and spine for your sweep function.  You can adjust the extremities with other slef made curves.
For your thread you should do the same, Helix curve, thread profil along a sweep surface... It might take some times to build the curves but it works.
Mail me if you wanna some files.
(i use R9SP3).....waiting R10
Have fun,
Eric
catiav5@softhome.net
hi
By using the helix command you can also do a taper spring also along the surface. even you can use line command and say angle normal to curve type and you can draw a wrap curve. alos you have a wrap curve command too in GSD
I am using v5 r8
Regds
Amit
