Solvent Recovery
Solvent Recovery
I need to install a solvent recovery system at our plant that will recover ethyl acetate from a batch mixer.We would be recovering about 400 lbs/hour.We would like to do it under vacuum. Does anyone know of a good equipment manufacturer? Does anyone know of a ethyl acetate expert?
RE: Solvent Recovery
I will recommended that you go on this page:
http://es.epa.gov/studies/hml10006.html
Then you may contact J.M. Teale Associates
