Set Default File Location
Hello All,
I would like to know where I can set my default file location in ACAD2014. When I click open file it will search in that location only. I know it store previous file, but if I want to look in the main folder, this is what I want to setup.
Thank you
KenJG
RE: Set Default File Location
A lot of the typical file locations are stored under Tools -> Options, top left tab.
Another variable that may help is REMEMBERFOLDERS, depending on which way you might want it to work.
