SolidWorks Explorer Question
I hate to use this forum for questions, I know I can find the answer to
...but I can't find it.
If you rename your parts in SolidWorks Explorer, is there a setting somewhere that tells your parts to retain their old name in existing assemblies?
Everything works fine, like I'm accustomed to - the new name bleeds through to my existing drawings, but in the assembly tree in which these parts are subcomponents, they retain their old name.
It's just a display problem because when I 'open' the 'old part' a new window opens up with the 'correct' re-named name.
SW Professional 2014
SW Electrical 2D/3D
64 bit SP1.0
Intel Xeon X(R) CPU 1603 0 @ 2.80 GHz
8.0 GB of RAM
NVIDIA Quadro 2000
RE: SolidWorks Explorer Question
Out of curiosity, what happens if you ctrl+q? Suppress the part then unsuppress? Just throwing some ideas out there.
Jeff Mirisola, CSWE
My Blog
Yeah - I tried that exactly - maybe, this isn't supposed to happen - I thought it was a setting I neglected to check.
SW Electrical 2D/3D
64 bit SP1.0
8.0 GB of RAM
NVIDIA Quadro 2000
**The answer - as far as I can tell - correct me if I'm wrong - 'Make sure the 'Component Properties'\'Component Name' - in the Upper/LeftHand Corner of the tabbed box says the name you want displayed in the component tree.
SW Electrical 2D/3D
64 bit SP1.0
8.0 GB of RAM
NVIDIA Quadro 2000
I assume you are renaming each part individually using the "Rename" tool in explorer... if so do you have the "Update where used" selected? Because when I do that and I have several assemblies referencing that file I can select which ones I want to update and which ones I don't. If you select one at all, then the new named file is its own part and the original part and its name will remain. Basically you will have 2 files now.
Scott Baugh, CSWP pc2
Berry Plastics
Cad Admin\Design Engineer
GEASWUG Greater Evansville Area SWUG Leader
www.scottjbaugh.com
Quote:
"If it's not broke, Don't fix it!"
Yes sir! That was all I needed - exactly. It can be so frustrating when you know all it is-is a setting.
SW Electrical 2D/3D
64 bit SP1.0
8.0 GB of RAM
NVIDIA Quadro 2000
heh! awesome. Glad i help :)
