Challenges in distributed generation
Hello All,
I am looking to understand the reasons why distributed energy resources do not yet make up a significant portion of generation. The idea has obvious benefits (more reliable system, decreased losses, etc.) and the installation of renewable resources is encouraged by many utilities and civic bodies; yet it does not seem to have taken off in most areas. What are some of the barriers or challenges associated with installing distributed generation systems? And do you think that their prevalence is likely to increase in the future, or will they continue to make up a relatively small portion of generation?
Thank you!
Thank you!
RE: Challenges in distributed generation
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
I have seen requirements for small DG to interconnect to MV lines which require distance relaying, in addition to IEEE 1547 requirements. Unless the DG has some huge $$$ incentives, it is not often financially feasible for small scale. As a recent example, a 850 kW cow manure digester plant was over $1M for the plant alone. A dedicated feeder to the substation was $200k. Don't exactly know what the additional PT's and relaying on utility side was. The only real winner there was the farmer.
Also, I don't necessarily accept your "obvious benefits", especially regarding reliability.
I remain skeptical that distributed generation will play anything more than a secondary role in overall power production until there are major technology breakthroughs that allow cheap storage of generated energy and cheap transmission of bulk power. I don't see either on the horizon. The only exception might be PV systems, but even those will be quite limited in terms of the total energy requirements for the grid.
