Is a welded tubesheet joint a category B or C?
Is a welded tubesheet joint considered a Category B or Category C joint? And if an efficiency of 1.0 is wanted, does it have to be RT'd (or UT'd)? Here is a pic of what i am talking about . . . .
Also, if i specify a Joint Efficiency of .85, is it governed by the lowest joint effiency of the entire vessel? For example, I have a heat exchanger with welded tubesheets and welded channels with mutiple nozzles. The nozzles have a Category D, Type 3 Joint with no RT, does that make the vessel a Joint Efficiency of .60?
RE: Is a welded tubesheet joint a category B or C?
jeevesme, I believe a tube-ts weld joint has no category assigned. UW-3 states that not all weld joints are categorized.
Second, joint efficiency is applied only to butt-joints. Corner joints are assigned E = 1 when needed. See Table UW-12 Type (7).
Third, joint efficiency is used for design of a single component only. E for any component does not depend on the E of any other. See UW-12, second sentence.
Your nozzles likely are corner joints, no E needed.
Recommend further reading, including Appendix L.
Mike
I think we are going to have some of the joints UT'd or RT'd for peace of mind . . . . but it boggles my mind that an entire heat exchanger can be built without having any RT done and still have a Joint Efficiency of 1 per code.
jeevesme,
Your joint shown is Catagory C. One can make tubesheet to shell welds as catagory B as well.
Thanks for quick replies guys. Much appreciated. thumbsup2
If Joint Efficiency only applies to butt welds, why does the code address weld types 4,5,& 6? Also, I just found this article...... Look at question 4....Wouldnt this indicate that nozzles are taken into consideration when it comes to joint efficiency?
Joint is 100%. You need a separate procedure to weld tube to t.s.
I might have more properly said "Second, joint efficiency based on RT is applied only to butt-joints."
Mike
Your configuration is showing Cat C Type 7 joints. RT/UT is not applicable for these joints since there is no applicable efficiency. They need to meet UW13 for corner joints, and you can meet your efficiency of 1 requirement on the vessel. There are other examples of this case in Code interpretations such as seamless pipe between fixed tubesheets in a heat exchanger.
If you require RT then go to a Butt Weld configuration with a hub machined into your tubesheet, but there are additional criteria such as App 20 if you have a plate or additional tensile testing to UW-13(f) for forgings.
The picture is not of a tube-to-tubbesheet weld.
I am not sure what component it is.
As has been stated, T-to-TS welds are a class of their own. Seal weld only, seal with filler, strength welds, again with and without filler, flush, recessed, back face........There are many variations and each has its own needs.
Plymouth Tube
Yeah, never did understand the sketch.
jeevesme, as to tube-ts joint, I still do not assign it a category. It is a Type 7 corner joint, no RT needed, E = 1, if needed.
Your nozzles and cylinder-tubesheet joints appear to be corner joints, no RT needed, E = 1 if needed.
If cylinders are butt-welded, both Cat A and Cat B joints, E will be assigned based on RT selected. E will only be used for design of the cylinders, and perhaps some other calculations such as in Part UHX, but will affect only the cylinders. Cat A joints likely will govern.
Your vessel has no "overall" joint efficiency.
Mike
