isometric view
isometric view
Hello World!
I want to develop in macro that create an isometric view in a CATDrawing from a product!
help please!
regards
help please!
regards
RE: isometric view
Try
CODE --> CATScript
' Create a view called "Isometrical View" in the sheet Dim oIsoView As DrawingView Set oIsoView = oSheet.Views.Add("Isometrical View") ' Retrieve it generative behavior Dim oIsoViewGB As DrawingViewGenerativeBehavior Set oIsoViewGB = oIsoView.GenerativeBehavior ' Declare the part to draw in this iso view oIsoViewGB.Document = oPartToDraw ' Define this view as a iso view, with the XY plane (in oPartToDraw) as projection plane oIsoViewGB.DefineIsometricView 0.925456, -0.042455, 0.376469, 0.109966, 0.981023, -0.159692 ' Position the View in the Sheet oIsoView.x = 300 oIsoView.y = 400 ' Update the view oIsoViewGB.UpdateRegards
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
RE: isometric view
thanks a lot :)
the program runs! but i don't know why the TopView is inclined!
the fact that i work in a CATproduct, I want to change projection plane to another part's plane
but i don't know how!
is it possible?
regards
RE: isometric view
