BS EN 10025-2:2004 Mill Certificate
Morning all;
I hope someone can help who is in the know. I have been looking at a number of 3.1 mill certificates against a BOM and found an issue (I think).
The material requested is S355JR+N but on the material certificate it just says S355JR. I have queried this back to the supplier and they said not all mills state the +AR or +N. Is this correct? I would assume if you ask for +N or +AR it should state it on the mill cert?
Hope someone can help?
Ant
Ant
RE: BS EN 10025-2:2004 Mill Certificate
"If an inspection document is required (see 8.2) the delivery condition shall be indicated in it with its specific symbol (+N, +AR or +M). In case the products are ordered in the delivery condition +N, +AR or +M the specific symbol (+N, +AR or +M) shall be added to the designation (see 4.2.2).
