Command Lines in Ansys Mechanical
Hey there,
I have the problem that the ANSYS iterative PCG solver underestimates the difficulty of my model and crashes because the guessed maximum number of iterations is not enough. That's why I want to increase the multiplier MULT in the EQSLV command. I am working with ANSYS Static Structural in Workbench and I wonder how to get this command in there since I don't find the option in the solver settings.
Anybody who knows how to get this right?
Thanks!
Alex
RE: Command Lines in Ansys Mechanical
I think you should check the NEQIT command and set pred,off to turn off the prediction of the number of iterations before convergence.
And by the way, you will want to insert command snippets, these parameters can't be set in the solver settings.
Thank you very much! That ultimately solved my problem! :)
Best wishes,
Alex
