Moving load - accurate start and stop behavior
Does anyone know of a way to "start/stop" a moving load in such a way that represents the physical extents the moving load would start and stop from. Currently the moving load just appears out of space and starts rolling down the structure, then rolls entirely off. In reality (a bridge crane for example) would be limited by the bumper stops.
Thanks in advance!
Thanks in advance!
RE: Moving load - accurate start and stop behavior
If you are referring to the actual analysis and you want to terminate the moving load before it gets to the end of the beam, then just add in a joint however far from the end of the beam and end the moving load there.
This isn't necessarily governing a design of mine, I just want to understand the feature as best I can...
Thanks again.
That is correct, does assume the wheels roll off one by one. If your rear load is the maxi load, that could mean a higher than realistic shear at the end of the beam (because the rear load would never get that close).
If it were really important, there is a way to do this. You could specify each wheel load as a different moving load with a different start and end joint. Then apply them all at the same time. Certainly a bit of a pain, but it would accomplish the kind of analysis you want without the extra partial load conditions.
In my case the 4 wheel loads are equal, so I created a moving load pattern with single point load. Then I created 4 moving loads starting and ending at joints spaced at wheel spacing... worked exactly like I was picturing.
Thanks again!
