pro e drawings baloon attachment
in my drawing lots of datum points have been used, i want to remove them from drawing views and show them with baloon only, wanted to form table conataining all info like x distance, y distance, profile tolerance, whether it is possible to link datum tarhets with baloons with tables with use of rrepeat region, (I HAVE ONLY ONE PART, NOT ASSEMBLY)
(What do you think about taking all of the targets that you are reporting profiles from and throwing them all on one table on another sheet? The table would have these columns: dimension number, description, location x-direction and y-direction, and +/- profile tolerance for each point. All profile points would be identified on the features themselves throughout the drawing using simple balloon numbers.))
PLZPLZ Help me :)
PLZPLZ Help me :)
