Urethane Injection
Urethane Injection
Which is better for injecting an existing wall horizontal construction joint against potential leakage, a hydrophobic or a hydrophilic urethane? We are rewaterproofing the exterior of the wall but we wanted a second line of defence,
Is there a good but concise specification available anywhere covering the injection procedure?
RE: Urethane Injection
If it's a construction joint, it's more appropriate to use epoxy injection, as it fills any gaps with a structural strength material.
As far as a specification, I'm sure Sika (Sikafix HH) or one of the other big manufacturers have one handy.
Hyrdrophobic is what you are looking for.
Check out this product as an example (I have not worked with it directly):
http://primeresins.com/products/polyurethanes/prim...
2. I have tried to put together a concise spec for urethane injection. Please see the attached. Any suggestions or comments?
Dik
