Graduation marks in NX
How do i put graduation mark in NX 7.5 such as ruler protractor?
Any input would be appreciated!
Also, I'm sure there's a standard out there on marks like this.
Thanks!
Thanks!
RE: Graduation marks in NX
It is perhaps not exactly the thing you seek for but Using GRID you can get a similar sort of a display. (sorry i can check it in NX8 only and not NX7.5 as of now but hope this is there.)
I am attaching an image herewith.
Thanks and Best Regards
Kapil Sharma
Preferences (pull down) -> grid and work plane -> you can set the spacing and toggle on what you want
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
but there ia a Polar option too,
I have only used rectangular so I am sure sure how good Polar works, and if its possible to move the origin
www.nxjournaling.com
Of the basic styles, there are Uniform Rectangular, Non-Uniform Rectangular and Polar Grids, as seen below:
You can find the various Grid pattern options at...
Preferences -> Grid and Work Plane...
Also there are icons on the 'Utilities' toolbar to toggle ON/OFF both the display of the Grid as well as whether 'Snap Points' are enabled or not.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
And yes, you can have them ON and if effect in both Modeling and Drafting, although since the actual drawing origin is used for the Grid origin, this makes perfect sense when dealing with either of the Rectangular Grid patterns but isn't really that useful when using a Polar Grid, but then using a Polar Grid on the face of Drawing is of little value anyway since I've never really seen Drawings organized for a Polar layout where as Rectangular layouts on Drawings is the natural way to do things.
And you can also use all three Grid styles while creating a Sketch, again providing a natural way to work and for cases where you're sketching radial type designs, here is where the use of a Polar Grid can be quite effective.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
