ViewPortLayer ; am I dumber than usual?
Using V1R5, Fedora version, under CentOS 6.5, latest.
No issues of any kind were reported at installation.
I've produced a simple 2D model in model space, and went to paperspace tab1 to produce a drawing of one of the parts. ... for which purpose only two of half a dozen layers need be visible.
In two hours of beating on VIEWPORTLAYER, I've managed to freeze exactly one layer in that tab.
How am I holding my tongue wrong?
Mike Halloran
Pembroke Pines, FL, USA
RE: ViewPortLayer ; am I dumber than usual?
Maybe I'm not completely understanding this, but did you try the freezing the layers using the drop down menu of the layers toolbar? I know that that freezes the layer in both mspace and pspace, but for the purposes of printing a drawing it may work.
Best,
Medeski
What I want is to freeze most layers in each viewport, so that I can generate in paper space in each tab a drawing of just one of the multiple parts represented in model space on a different layer per part. ... exactly like VPLAYER does in AutoCAD.
Part of the problem may be that the mouse response is severely delayed on my old laptop. I could swear the prior release, or the one prior to that, was much less aggravating in that respect.
Mike Halloran
I was able to get it to work for me. I copy pasted the command prompt. The first 3 lines were automatically generated when I double clicked inside the viewport to get from pspace to mspace. Does it still seem like a lag issue?
: _ACTIVATEVIEWPORT
Default: 4
Specify viewport number to activate» 4
: viewportlayer
Options: ? to list, LColor, LStyle, LWeight, Frozen, frozen from New, Reset, Thaw or Visibility default
Specify option» F
Default: Specify entities
Specify layer name(s)» HIDDEN
Default: Current
Options: All, Select or Current
Specify option» C
Also, the cursor in the graphics field lags the computer's cursor by a couple of seconds, and it seems to have a predilection for a 'box select' instead of a single click to select what's in the target box.
Mike Halloran
